Rockford Fosgate punch EQ work good
  • 2
TDC
Canada
Hi im running an Kicker L7 Qclass 12” sub with Fosgate p1000x1bd . I have done the Clean set up . My gain landed at just over half way mark. Amp doesn’t seem to kick super hard unless i turn up the Punch EQ on the top of the amp. The amp’s gain is set to the HU so there’s the power i have available and its not enough unless like i said it needs abouthalf way on punch dial any thoughts? Thanks.
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm
If you’re at 2ohm you’re not feeding it enough power. At 1ohm that amp probably delivers 1400-+ at 2ohm check your spec sheet to see what your p1000 delivers.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
TDC
TDC
Canada
2023 LTZ
    May 18, 2024
    May 18, 2024
