Rockford T 2652-S speakers failing.... Reason?
  • 1
ckunke002
Hi, I have installed a set of these components a few years back. I feed each mid/tweeter combination with one amp channel (so they're not bi-amped). Today I noticed that the passenger side tweeter was not playing at all while I was trying to diagnose a problem with the driver side component set cutting out. I initially thought the entire driver side was cutting out periodically while driving, but when I was ripping the speakers out of the door today to try to diagnose the issue, I was able to see that the mid was still playing while the tweeter was cutting out. Maybe the mid never was cutting out to begin with, and only the tweeter.
Anyways I now have one of the crossovers pulled out of the driver side door hoping to learn something or see a problem, but am still unsure. Is this likely a crossover issue, or just tweeters going bad? If it is an issue with the passive crossover, is there an easy way to find the issue/fix it? Do I need to bi-amp maybe? Thanks for reading.
660
The surprise wasn’t that they didn’t offer one…it’s how much engineering went into making it easily replaceable, and then not offering one. Maybe...
Thanks ya. Just pulled the trigger on the 1500BDCP because of the constant power that RF developed to help with the ohm rise.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
ckunke002
ckunke002
Portland, OR
ckunke002
    May 18, 2024
    May 16, 2024
