SOLD ROCKFORD T600-4 amp FS $150
lucas569
ct
selling this hella cheap! $150 + shipping. bad news is it needs repair. not a big deal really but thats why im selling so low.If i repair im keeping it! Its that frickin sweet and its mint too! This amp is way underrated check out the review of its little brother the T600-2, you can see this RF series easily is 20-30% underrated http://www.caraudiomag.com/testreports/caep_0709_rockford_fosgate_power_t600_2/index.html
i hit a huge pothole in my home town and the Pos+ wire accidentally came loose now it has some static noise coming thru the channels. even after repair your getting a hell of a deal, ill post up pics soon.
specs/details here http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=104&family_id=107&item_id=107997&locale=en_US&p_status=
Number of Channels 4
Rated Power
continuous power 100W x 4 @ 4-Ohms RMS
150W x 4 @ 2-Ohms RMS
300W x 2 @ 4-Ohms bridged RMS
2-Ohms x 2 bridged Stable
Total Power
total sum of 'rated power' 600 Watts
Dynamic Power
powercube measurement (info) Front Channels
139 Watts x 2 @ 4-Ohms 0° Res
236 Watts x 2 @ 2-Ohms 0° Res
Rear Channels
140 Watts x 2 @ 4-Ohms 0° Res
Bridgeable Yes
Efficiency (average) 70% @ 4-Ohm
64% @ 2-Ohm
Crossover Controls Front High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Front Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Rear High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Rear Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Tone Controls Front Channels - Punch EQ
Treble: 0dB to +12dB @ 12kHz
Bass: 0dB to +18dB @ 45Hz
Rear Channels - Punch EQ
Signal Input Front Low level: 1 RCA pair
Rear Low level: 1 RCA pair
Signal Output Low Level: 1 RCA pair
Power Input Connector Block
Power Wire Gauge 4 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls Optional Remote Punch EQ
(overrides rear channel built-in Punch EQ)
Visual Indicators Power
Thermal
Protect
Circuit Topology Class Class A/B
Frequency Response 20Hz to 20kHz +/- 1dB
Shipping Weight 12.00 Lbs.
(5.44 Kg.)
Dimensions (HxWxL) 2.14 x 8.14 x 14.91 (in)
5.42 x 20.68 x 37.86 (cm)
646
The surprise wasn’t that they didn’t offer one…it’s how much engineering went into making it easily replaceable, and then not offering one. Maybe...
Thanks ya. Just pulled the trigger on the 1500BDCP because of the constant power that RF developed to help with the ohm rise.
982
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
lucas569
lucas569
ct
lucas569
    May 16, 2024
    May 16, 2024
