Hookedup12 10+ year member
1 ssa dcon 12 svc 4 ohm 300wrms
I want to bridge it a 4 ohms and run it a 400w rms to my dcon. But by bridging the 2 chan amp will it get hotter or perform worse than a monoblock?? Will I notice an diffrence and what does it mean
By cea rated and 12v I want a Max of 400w goin to the dcon and it said something about 475w that would be too much
Boston acoustics gt 2125
GT Reference Series 2-Channel Amplifier
RMS Power Rating(CEA-2006-A):
4 ohms: 125 watts x 2 chan.
2 ohms: 200 watts x 2 chan.
Bridged, 4 ohms: 400 watts x 1 chan.
Bridged, 2 ohms: 600 watts x 1 chan.
RMS Power Rating(12V):
4 ohms: 95 watts x 2 chan.
Bridged, 2 ohms: 475 watts x 1 chan.
Remote bass level input (GT-RSL remote level control sold separately)
Red LED power badge and orange protect indicator
2/1 channel operation
Adjustable mounting feet (mounting feet move along rails to allow the easiest installation)
Fully computer-controlled diagnostics system (continuously monitors amplifier in case of thermal overload, short circuits, or over voltage)
Q-Tune™ technology combines sophisticated crossover adjustments with Q-Control settings to seamlessly transition rear bass to the front sound stage
Uses a 40 amp ANL fuse
Heavy duty fan cooled aluminum alloy heatsink
Gold-plated RCA level inputs
Gold-plated screw terminals
Variable high-pass filter (20-350 Hz, 12 dB/octave)
Variable low-pass filter (50-350 Hz, 12 or 24 dB/octave)
Signal Voltage Input (200mV-8V)
Frequency response: 10-95,000 Hz
Dimensions: 13-1/4"L x 9"W x 2-3/8"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
1-year Manufacturer's warranty
