SAZ 2000d - speaker terminal hook ups?
  • 6
reclessantics
SC
Just got my amp but wanted to double check -
so i read the manual, and you basically only us, 1 set of speaker terminals?
just more options for ohm wiring?
so if i have a single 12 (ex) @ 4 ohm, ill just hook it up on the right terminals ( - +) like the manual says,
and if i have 2 12's each 2 ohm (and i want to run @ 2 ohm) id hook it up like its a 2 channel, each speaker to a terminal? but if i want to hook 2 d1 subs id wire them to 4 ohms, or w/e, but use 1 terminal? does it matter?
just can't use both for 1 sub, or 1 sets of pos/neg wires , (like bridging)
word just wanted to double check, so stick to the right one, even if im wiring 2 subs together? (ill come to a single pos and single neg anyways.)
lol i said that as an example
I was just poking fun at you. My cousin made me laugh when he brought me his MTX 81000d and said "Dude, my amp is so badass.... I only have one channel hooked up and it makes my 13w7 hit so hard!" He was a little disappointed when I told him that his MONOBLOCK has two sets of speaker terminals for wiring options ONLY!
haha yeah i caught that its all good yeah man i love it, just hooked up a shiesty sony xplod, @ 4 ohms. till my mj 18m's get here //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
but still i think im gettin a wee bit of voltage drop.. big three, stock alt and batt. its in a chevy silverado 1500.
i thought most stock elec. can handle at least .6k watts? and im no where close max on the gains. i have a 60x4 and maybe 400watts out of the SAZ.
going to go snag a voltage meter asap
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
265
362
331
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
reclessantics
reclessantics
SC
reclessantics
    May 18, 2024
    May 16, 2024
