sealed box for a XXX18 v3 ...?
SEBASTO
what would be the best sealed box volume for a XXX18 v3 off a 2kW Hertz amp....
and yes.....this sub was made for SQ //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
As far as i know there should only be the old style (like urs) and new style (the huge looking one)... What's a V3?
EDIT: As far as your question goes... i've heard XXXs like BIGGG boxes, so do maybe around 6-7 cu ft sealed? It might just be in the small side though...
there's another version of that motor also...one with a flat backplate
Yup, I have an 18" from '03 with the flat back plate, slightly different than your old '05 12" that I've got sitting here right now as well. Finally picked up the wood for the box earlier tonight. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yp ...i have that motor too
now ...the box will be 4.5 cubes ....hope it sounds good
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
12
If you experience any air leakage from the screw holes.. adding Clear or the color of you choice of Silicone works just fine after a 24 hour cure...
10
Stereo Integrity hst12, only needs .6cuft after displacement. I have mine in a 15 inch double wall birch ply cube, .55cuft after displacement...
7
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
SEBASTO
SEBASTO
somewhere in Europe
T3mpest
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
