Sealed Box frequency??
  • 4
jigsISF
Are sealed boxes tuned to a certain frequency or is that just for ported enclosures?
The reason I ask is I have a sealed box and was wondering when I get my system hooked up, what I should set the subsonic filter to. I heard usually a few hertz below the "tuned" hertz. Here are the specs of my box and speakers:
2 Fi Q 12" :
Fs: 34.2 Hz
Re: 0.7 Ohms/coil
Qms: 7.63
Qes: .39
Qts: .37
Mms: 249g
Cms: 0.87mm/N
Sd: 481cm^2
Vas: 28.3 l
Spl: 86.5dB 1W/1m
Bl: 13.9 N/A
Xmax: 28mm
Rms: 1500W
Sealed box: .8-1.5 High QTScuft
Ported box: 1.8-2.5 cuft @ 28-33Hz
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 7.000”
Displacement: 0.16cuft
and the box specs (sealed):
- 3/4" and 1/2" MDF Construction
- Black automotive carpet
- Holds 2 round 12" subwoofers (10" subs may be substituted upon request)
- 1.15 cubic feet per chamber (volume can be reduced upon request)
- 9.5" mounting depth
- Round spring loaded speaker terminals
- Sealed air tight w/liquid nails caulk
- Roughly 25 lbs.
So vas x box volume in liters + 1, find the square root of that then x the resonant frequency, in that order or do you follow basic order of operations
no. Vas/Vb (ltrs) then add 1, then sq rt that, then multiply that by the fs of the woofer.
in regards to the OP, the Fc is where you are going to start rolling off. I have found that you are good for about one octave under the Fc playing wise. Granted it will have a gradual roll off, it is more pronounced the lower and lower you go.
You don't need a subsonic filter with a sealed enclosure. The woofer suspension will always have the extra resistance from the pressure in the box, so it can't unload like a ported box woofer.
unless you go incredibly large, but that would be pointless. So yes, good point!
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
12
If you experience any air leakage from the screw holes.. adding Clear or the color of you choice of Silicone works just fine after a 24 hour cure...
10
Stereo Integrity hst12, only needs .6cuft after displacement. I have mine in a 15 inch double wall birch ply cube, .55cuft after displacement...
7
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
jigsISF
jigsISF
columbia, sc
RangerDangerV2
