Sealed Box SPL numbers?
Vehicle: Chevy Silverado reg cab
Electrical System: 250a excessive amp alt, no big 3, stock battery
Amplifier: memphis 1000d (gain set at 600rms)
Subwoofer: 12" mag d2
Box: 1.7 sealed
Mic: TL
Song/Tone Played: 34hz
db Result: 139.6 IIRC (in kick)
BTW the mag easily has 140 in her. I just dont like giving her 1kw and burping it in a large sealed box at 34hz //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif I'll stick with the above score with 600rms.
Good description of what im trying to do with my truck....just gotta boost my frontstage a little.
I wish I was getting to go to the shreveport show. I'd let you hear my truck. Your setup definatly has the potential for 139+ //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
If you experience any air leakage from the screw holes.. adding Clear or the color of you choice of Silicone works just fine after a 24 hour cure...
10
Stereo Integrity hst12, only needs .6cuft after displacement. I have mine in a 15 inch double wall birch ply cube, .55cuft after displacement...
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
Chevyaudio
:poof:
Chevyaudio
Back in the Dirty BR, Louisiana
dkc62
