First post. Thanks for this great forum, I have learned a ton.
I have being reading about being better if using RCAs outs to amp because:
1. They are shielded plus less prone to picking noise.
2. They are not amped so no noise and distortion from HU.
About that, I have to ask:
1. Can you shield high level outs?
2. Can you also ground them as some people do in their pioneers when the pico fuses are blown? I understand alt noise comes from alt AC ripple and ground issues. This should help, but, would this make as a shield for rejecting other noise sources too?
3. I seriously doubt a decent HU would give such a bad amplification (talking about less than half the gain here) that, if reamped, it would be noticeable as a loss in sound quality. If someone has real world experience in comparing these two sounds (going high level to amp and going RCA to amp) please share.
4. I also read somewhere that high level outs when shielded, made bigger fields so they were noise generators. However, this was on a public address speakers article. Is this true for shielded and/or unshielded high level outs of the likes found in a HU?
If RCAs are good because of the noise rejection as I read, shielding speaker level outs should yield the same resilts, I think. However, the signal to noise ratio in a high level out would let you hear the noise only if hearing at very low volumes. So, I think a shielded cable be it RCA terminals or not, would pick the same amount of noise, just because it is a cable. Am I right?
Well, thats just my reasoning, but would be good some wxperience here, especially in the sound quality real-life experiment if using high level instead of RCAs.
Best, good day and again, thanks for this great forum!
