Single Din Headunit - Nothing fancy
  • 4
2000Gator
Hey Guys, just looking for a basic single din headunit to go in my car. Nothing fancy, but would like it to come with all accessories from new and to function/look 100%. Would prefer Kenwood, Pioneer, Alpine. Aux/usb preferably as well. Would like to spend under $100.
What type of car is this going into?
I can do my Kenwood KMM-308 (has front USB and AUX, 1 set of Pre-amp outputs) which is still NIB with installation parts for $65 shipped. if you want me to solder the harness for you, I can do that for an additional $5. so $65 for the radio and installation parts. $70 for radio, installation parts, and soldered harness.
Is the full part # kmm-BT308u? I don't see just a kmm-308 out there. Are you including the dash kit as well? Will the terminations be soldered and heat shrinked?
The 2000 Corolla is a single din set up so it would just the headunit only with no extra pocket. If you're including that I will purchase the headunit. To confirm it's $70 for NIB headunit with all accessories, wiring harness soldered, and install/dash kit correct? If this is right either pm or post your paypal and i'll get the $70 to you.
PM'd
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
914
Check each speaker for shorts. A pinched wire grounding out or a individual blown speaker can sometimes make the internal amp go into protection.
7
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
611
2000Gator
2000Gator
Baltimore, MD
fasfocus00
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
