Single Orion H2 15.2 or two Audio System KRYPTON 12"
  • 1
Mitkoman
I have an Audiopipe ap1800d amp. I can get for about the same price used orion H2 15.2 and run the amp on 1 ohm, or also used pair of Audio System KRYPTON 12" , wire them in parallel and run the amp in 2 ohm. Either way, I can give the amp about 90 ampers of current, so I wonder what to choose in order to be louder and lower at about 1000 watt rms.
I think you are familiar with the Orion H2, and here are the specs of the KRYPTON 12:
30 cm High Performance Subwoofer
1500/1000 Watt - Impedance 4 ohm
Qm 9,45
Qe 0,41
Qt 0,39
Fs 37 Hz
Vas 30 L
Mms 191 g
Cms 100 µm/N
BL 17 Tm
SPL 95,5 dB
Rated 1000 Watt
music 1500 Watt
X-max (+ -) 17 mm
Installation depth 170mm
Installation diameter 283mm
Any help appreciated.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
611
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
914
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
4
Mitkoman
Mitkoman
Sofia,Bulgaria
Mitkoman
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
