TheJuggla1 10+ year member
I just grad high school so the vehicle I had the last year isn't that great, currently a 94 safari, now it needs front end work it won't last me till I have enough to buy a really nice 2000+ish vehicle. I was either looking to upgrade to a newer one or get a suburban for under a grand(I need a large vehicle to old my 15"s), till I can save up for a more expensive vehicle.
So I see this 1997 Safari for sale for $500, not bad but not perfect, new tranny with under 100k, but It doesn't say the total kms on it, ill have to look into that but I lost my drivers license(too many tickets for 1+ passengers grrr) so I have a month and a bit to do some work. This guy says a week or so ago it had an oil leak.
"on Friday, when i drive from work, I heard little knocking into the engine after 4 maybe 5 miles oil from engine goes out and i have end of my trip... I towed it into the driveway and that's it... probably easy to fix because I can turn on the engine, but don't work normally so it's not able to drive... maybe only oil pump is unscrew and make a hole into the oil pan when turning around and around... i don't know, I don't have time for this... "
So I think I wanna buy this and then keep my older safari for parts in case, since I just need a vehicle to last me about 8-16 months, I can most likely fix this and with parts from my older van it will be even easier, but did he damage the engine running for a bit with low oil?(by the sounds of it he started it up after he towed it back which means the oil was probably almost empty) Or will I end up fixing it down the road?
