Sony XAV-9500ES help
  • 1
eenyuheye8o8
2016 Mazda CX-5 with long extension harness from factory amp
Gonna just try make bullets
-9500es
-Working good for about 2 weeks
-screen stopped turning on
-checked harness wiring
-got 12v from yellow and red when car on
-checked ground to multiple points with DMM
-pulled radio out and harness and directed the leads to see if it works but radio still doesn’t turn on.
-checked radio fuses and car fuses all good
-got replacement from crutchfield
-radio worked for 6 days
-this morning screen and radio was resetting on and off. Got videos.
-called tech support at crutchfield again and they are sending a new harness cause the red on the radio harness wiggles a bit. Yellow and black solid don’t move.
Any one else have issues with those single dins with removable monitors
or is there anything else I can check?
gotta upload the video on YouTube files too large.
That looks like it can work for backup cam for sure, thanks
926
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
You will have to pull the unit from the dash to view the model # and Serial # either on top/bottom that will have a sticker and usually a wiring...
I have a Sony xav ax5000 that won’t come on when plugged into the truck harness. I have tested it on a 12 volt battery and it will come on that...
eenyuheye8o8
eenyuheye8o8
Mililani, Hawaii
eenyuheye8o8
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
