Speaker cracking and static noise
adam68
Newbie here. Put a Pioneer DEh-single DIN in my Mustang. The Turner and XM work great. When I use the Cd and or the USB, I get static or cracking sounds through the speakers.
I noted that the radio will operate w/o the blk ground wire attached as the unit grounds to the dash
This sound is not heard when engine is off and key on. Suggestions and or settings on the radio to try. Does that HPF option work for this?
Thx
Alot of pioneer heard units need to be regrounded either on the rcas or a short one to any metal piece that's connected to the frame and the vehicle and the head unit itself
427
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
416
554
472
adam68
adam68
los angeles
Dr. Slam
    Jun 1, 2024
    May 31, 2024
