speaker sizes
  • 4
josh b
i'm about to buy a 95 plymouth neon but i need to change the mains out. i want to put MTX mains in as the replacements, the only problem is size. i can switch the 6x9s in the rear but the fronts are 6 3/4s and i can only find 6.5s in MTX. would the 6.5s be able to fit in the 6 3/4s hole? any help would be appreciated. thanks.
well dude, you have been mistaken, i did some research and the fronts in your car are actually 6.5s, so yes, the 6.5s you wanted will fit
523
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
460
621
530
josh b
josh b
Colorado
Baller492
