Spring terminal broke
  • 2
Pictures?
You can order those terminals from a couple places online. Can't remember where I've seen them recently but I have. If you strike out I may have a spare Sundown push terminal here though I'm not sure if SA series uses the ones I have. It may be tricky to get the nut back on the post tight with the sub assembled though.
Alternately with some patience and a steady hand you may be able to get what's left of the old terminal out of the hole in the frame and solder some 8 gauge cable directly onto the tinsel. Be sure you use some zip ties and/or glue to keep it tight in there though.
Super easy and Cheap..Ill bet your father or Gramps can solder it pretty easily?? You Tube is your friend too. As well as H.freight /Lowes/or...
14
They make sleeves that go over the battery terminal to increase its size.
BigAl
BigAl
birmingham,al
hispls
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
