still getting voltage drop
low 10's??? that *****. i got a stock 70A alt and i only drop to 10.5V thats w/ 1500W sub amp and 150W comp amp.
not to steal the thread...halfway same topic. if i was to get a good battery (optima or something) and stick w/ the stock alt would this help my voltage drops any? the biggest alt i can get for my car is a 90A and 20 extra amps just isn't worth the $. eventually i'm gonna fabricate a bracket and find me a 110A to wire in there w/ the other //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
You will get a little bit of improvement but your alternator still isnt going to be able to keep up with the load beng drawn on the battery. You may want to see about putting a deep cycle in the trunk which you will have to slow charge every know and then, that will help keep the voltage sustained for a while.
Toyota is really efficient. Usually the life of a Toyota last 18 - 25 years before the car or truck begins to wear down. 25 years then fixing...
16
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
11
added a 32AH bank to my system...... Cot damn! Now we rockin. Voltage staying above 13 wide open!! Just thought I'd update.
4
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
3K
Before you remove the amp, swap the front RCAs with the rear ones on the amp and repeat the test. Many guys here use the Pioneer amps and love...
bhsswrstlr
bhsswrstlr
Indiana
blackgeltabs
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
