Stock amplifiers with aftermarket system... help!!!
  • 2
Is there any way i can use my stock amp for the rear stock speakers with an aftermarket deck??? or does anyone know a site where i can get wiring diagrams for free? i was thinking about getting a chiltons for the diagrams but i dont even know if it would work... Get back to me if you have any comments or suggestions... the car im doing the install on is a 1997 buick park avenue ultra... get at me!
I think the problem you might run into here is getting signal from the aftermarket radio to the stock amp. (RCA's). i wanted to do the same thing in my car, but couldnt find out how to do it. i just had to do an amp bypass. best of luck to ya
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
6
283
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
575
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
371
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
563
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
sTony1987
sTony1987
United States of America, Minnesota
Alhart
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
