Sub/amp Qualification for mustang 2017
baklulu19
So, I have planned to get "HDS3.112 Subwoofer"
( SoundQubed HDS3.112 )
with
"SQ-12LSVDD 12" Soundqubed Single Vented SPL Box"
( https://www.atrendusa.com/soundqubed-12-soundqubed-single-vented-spl )
pairing with
"AudioPipe APCL15001D High Power Mono 1500 Watt Max Class D Car Amplifier"
( https://www.amazon.com/dp/B00BW54418/ref=cm_sw_r_cp_apa_yM2HzbQTR52AN )
via
"4-Gauge Amplifier Install Kit"
( 4-Gauge Amplifier Install Kit )
and
"NVX XPLOC2 High-Low converter"
( https://www.sonicelectronix.com/item_46220_NVX-XPLOC2.html )
QUESTION - How is Soundqubed sub ? I have never experienced it. Can we compare it with Alpine subs or JL subs? Does any one has any similar setup? how is it ? I am only getting single ''12 inches sub, Will that be enough to feel the bass within car? I listen to hip-hop kind of music mostly. Will I need any extra Battery to run this setup? My car is brand new tho with head unit stock and everything stock yet. I'm not planning to upgrade head-unit any soon.
Thanks in advance for visiting this post guys.
many peeps don't think sq subs play deep or have any sq (ironic huh?) and those atrend boxes are tuned to like 40hz i checked.. some peeps have had problems with ap 1500's lately., how much power do u actally want u can get cab 1600 for $199 hugh amp very popular., u can get amp like mine $169 ppi p1k (tested @ 1162rms @1ohm) and it does 930 rms at 2 ohms (tested) it's better to get 2 or 0 g wire if u gonna run more than 1k (i have 4ga) but if u add 2nd amp u be glad u have the thicker wire.. check out those amps and look at sundown sa or FI ssd (made in us).. * NEW * CAB-1600.1 Amplifier - Car Audio Bargain * B-Stock* Sundown Audio SA-12 600W SA Series - Car Audio Bargain bstock is just as good as new but with a 30 day warrnaty new they $214 SSD Series - SSD12 | Fi Car Audio 12-Inch CUSTOM-PORTED MDF CAR STEREO SUB WOOFER ENCLOSURE 2 CU. FT. TUNED @ 32Hz | eBay
If youre gonna spend x amount of dollars on a new amp, better to spend that same amount on a used amp from atrusted member on here. Shop wisely and youll get motr power and better reliability imo
Check out the FU audio 1250 12" in a custom box. Also I would do Knukonceptz amp wiring kit as well over the Soundqubed. Go with the CAB 1600 amp over the Audiopipe too.
I personally would do
FU audio 1250 sub FU Car Audio, fu audio, fu car audio
CAB 1600 amp * NEW * CAB-1600.1 Amplifier - Car Audio Bargain
Knukonceptz amp wiring kit Bassik 0 Gauge Amplifier Installation Wiring Kit - Merchandise
custom built box or this one if you can't build one FU Car Audio, fu audio, fu car audio
Also does your car have the upgrade stereo system or base stereo. With the amplified system its little more than just a LOC.
690
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
778
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
789
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
baklulu19
baklulu19
Vancouver, BC
maylar
    Jun 2, 2024
    Jun 1, 2024
