Sub and amp combo
  • 4
Take 2
Thank you
http://www.caraudiodirect.co.uk/subwoofers/sub-amp-packs/jbl-series-2-car-audio-subwoofer-bass-pack-inc-12-sub-in-original-subwoofer-box-mono-amp
This kit comprises of:
1 x JBL GX-A3001 Amplifier1 x JBL S2-1224SS - 12" 1100W Bass Slip Stream Enclosure1 x 8 AWG Wiring Kit (May differ from image shown)
JBL GX-A3001 Amp
Number of Channels/Type: Mono / Subwoofer4-Ohm Power Output: 200 W rms x 1,2-Ohm Power Output: 300 W rms x 1,Total Peak Power Output: 415 WattSignal-to-noise Ratio (IHF-A) 98 dBFrequency Response: 10 Hz - 320 HzVariable Electronic CrossoverInput Connections: L & R line-Level (RCA)Speaker Connections: 2Signal Output Connections: line -Level (pas-trough)Dimensions (H x W x D – Metric/English): 291 mm x 206 mm x 52 mm
JBL S2-1224SS Sub Enclosure
Type 12" (300mm) enclosureEnclosure Type 12" (300mm) Slipstream ported enclosureAmplifier Power (RMS) 275WAmplifier Power (Peak) 1100WFrequency Response 25Hz – 175HzInput Sensitivity 93dBDimensions (H x W x D – Metric, English) 600 mm x 330 mm x 415 mm
8AWG Wiring Kit
5 meters of 8 gauge power cable5 meters of remote cable5 meters of RCA interconnects1 meter of 8 gauge ground cableFuse holder with fuse;TerminalsCable ties and cable grommets
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
11
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
680
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
776
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
9
782
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Raj iqbal
Raj iqbal
Uk
BOOMINGRANDPA
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
