Sub question
  • 4
snipe523
Troy, NY
Ok I've been out of the game for a good 5-6 years and it seams like everything has changed in the audio world in that time. There are a bunch of new companies now that I have no clue about. I am in the market for 2 8" subs with a max mounting depth of 5.25". These will each get about .5 cubes in a sealed box. My main goal with these subs will be good sq. I like to crank it up now and then but I don't need them to shake my truck apart. I just want it to sound good when I do crank it. So of the new crop of subs what would you recommend that meets my criteria?
Sundown sd-2 8.
I had six of these in a quasi-6th order enclosure and it got loud and low.
For the application you described these fit the bill.
The sd-3 line has been released but no mention of the 8's from sundown in the sd-3 line. The difference between the sd-2 and sd-3 8 is the surround design and some cooling improvements. Other than that they are basically the same sub.
Amazon.com : SD-2 8 D4 - Sundown Audio 8" 300W RMS Dual 4-Ohms Subwoofer : Vehicle Subwoofer Systems : Car Electronics
Sd-2 8's or wait for the sd-3-8's.. You could also take a look at sd-3-10's since they have the same mounting depth as the 8's.. Not to sure on cube requirements off the top of my head. .5-.6 maybe?
Sent from my DL718M using Tapatalk
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
693
I would run a pair of 15s in an suv.. or run 4) 12s
24
3K
1.25 NET cubes. You have to add the sub and port displacement to the box. I'm guessing that you will be around 1.7 net before sub and port...
7
I swapped out a water-damaged amp from a '73 Mercury Cougar and wired four speakers (2 frnt Door/2 rear door panel) as shown here, but did not...
snipe523
snipe523
Troy, NY
djr4x4
