Sub recommendation
  • 5
Scott Motes
Number of subs preferred: 1
Size preferred (if configuration allows): 12"
Budget: $125
Power to be used (which amp(s), include which resistance): Rockville DB12 2ohm
Space available (take measurements, do not guess):1.8 cu ft ported tuned to 36 htz
Goals: deep bass
Listening habits: rap,  rock
Preferred brands/subs/whatever: sundown ...brand is not as important as sound Ihave been thinking Sundown E12 V.3 D4
skys the limit, but ive been interested in these 2 brands budget subs
reseilient sounds rs12 (3" coil on a budget sub doesn't happen to often)
crossfire c3 12 newest version (trusted brand)
So I looked at Soundqubed....Machette....and ended up going with the Sundown E12 V.3 D4 because it matched really well with the airspace on my enclosure
roger that, just got one from sonic electronix for $189. thanks for the help
18
This $100 over your budget but it checks every other box https://stereointegrity.com/product/bm-11/
10
I ran 2 10’s aero ported in my 06 mustang years ago. Each box was 1.2 and the subs were diamonds (can’t remember exact model). Best thing to do is...
10
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
508
Scott Motes
Scott Motes
Scott Motes
