subs amp underpowered?
lol the importance of a good head unit is always often overlooked. Good internal dacs make all the difference.
Honestly didnt even think of it being the head unit. The new one I did ground the rcas like showed the sticky thread and done a chassis ground on the ground wire connection on the harness also. Gains on both amps are much lower and it's just so much more enjoyable to listen too. I appreciate your time helping!
You said the subs are dual 4 ohm. Keep in mind that this means you have to wire them in series/parallel which will give you 4 ohms. Yes, the amp...
957
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
BassDrop69
BassDrop69
BassDrop69
    May 12, 2024
Brendon Jenness
    May 11, 2024
