Sundown amp crapped on me..
I hate to ask this question...
but I really don't know which one is the power?
I won't take offense to bashing =/
bam i found the problem lol
ground is the big black wire a.k.a kovemaster559 //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
So unplug the RCA's from my sundown, and disconnect the ground wire (black) and leave the power wire (red) and then turn on my car?
Thanks for being so patient guys
I disconnected the RCA's, and I disconnected the wires going to the sub
amp still turns on in protection mode
All i'm waiting on is an e-mail from Ben/Kevin from Low-hz for my invoice, so I can send it to Jacob @ Sundown so he can check it out.
I've been having no sub for almost 2 weeks now.
it ***** HARD
I'm sure it could be a really nice and neat job on that ground and all, or that the bolt passes through into a very solid part of the body. But for me personally I would double check that its sanded down to bare metal below the grounding terminal ring. Looks like there is a washer or something below it, maybe this is part of a sleeve that bolt goes into or something, but I would double check that and make sure its good bare metal going into a good piece of the body.
If its a solid ground and good contact on a good bolt then disregard all that, also its probably a good ground if it worked for 7 months without a problem. Hope you can diagnose the problem, if not I am sure you can get it fixed fairly easily. If you bought it new you should still have plenty left on the warranty.
Your amp should have a 2 year warranty, so no sweat just talk to Jacob.
Most likely culprit is vibration damage, breaks some legs off the mosfets, when this happens things go haywire and you could get some smoke coming out of the amp for sure. Not sure if Jacob will warranty it for you, but if not, give me a shout and I can repair it for you flat rate for $125, good as new. Email me for more details, sales@db-r.com.
3Series Banger
3Series Banger
Bay Area
dB-r
    Jun 1, 2024
    May 31, 2024
