Sundown audio
well see idk anything about wiring in ohms so i have it wired from + - on the amp and to the sub its + on one voice coil and- on the other then i have a wire connecting the remaining +- terminals
ok so you.re running @4 ohms which isnt gona be much output on that amp at all......get. a solid 1000-1500 watt amp and wire that sub at 1 ohm..both sets of voice coil wires going to amp..and it will blow u away..and get someone to make u a nice ported box
also i dont know what kind of electrical and wiring u have but you.re gona want to get a good 1/0 wiring kit ..i suggest audio technix. and do the big 3 and get. agood agm battery for under the hood and possibly addd a second battery to the back to keep you.re voltage from dropping too bad
Is American Bass better then Mmatts? Again I'm in love with quality and smoothness with alot of power and so far I'm Does the ABs have better...
12
Some of the NVX stuff seems alright, but the amps, especially the higher end ones, they seem suspect and sometimes show stats that straight up say...
13
5K
trev28
trev28
wausa,NE
RangerDangerV2
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
