Sundown E-12 box help
EC11
I got a sundown e-12 and i need help on what box to buy. I'm going to give it around 500 rms and i have a Altima. I wanted to go sealed because i want to keep it small, but i know ported will sound better/louder. How small could a ported box be, with the sub still sounding good. Or would it be possible for a sealed box to sound good.
What Buck said. Plus, Sundown recommends as small as 1.5ft for a ported box, which is only a little over half a cubic foot larger with displacement than the 1 cube sealed recommendation. So in the end, not much larger physically but a lot larger audibly.
ok thanks for the help. i mainly listen to hip-hop. So a 1.5 ft ported box being the best, could i get a pre-fab or should i get a custom made one.
You should get a custom one. I would like to see something like 2 cubes ported with a 4" aero, that'll sound great.
To be clear, I didn't say a cube and a half was best, I said it was barely larger than the sealed recommendation. Like Buck said, 2 cubes would be better (probably best for that sub) and an aero port is worth the cost.
Let him build you a box. From what I've seen, he has the knowledge to design and build a quality enclosure for you.
Sounds like you need new coils. My Explorer with three 15's, appropriate birch box, fully sound-deadened interior, and a boat behind it does not...
582
EC11
EC11
Cincinnati
bbeljefe
    May 31, 2024
    May 24, 2024
