Sundown SA 10 or 12...
  • 5
Teej
I can't decide!
I listen to a lot of rock, metal, electronic (mostly trap and dubstep), and some rap. I'm gonna put either sub in a ported box and run it off my Hifonics BRZ1200.1D that I have from my old build, but I'm not sure whether to get a 10 or 12. Space isn't so much an issue, but I do at least need to be able to fit my toolbox in the trunk with the sub (I drive a Jeep Cherokee XJ).
With that in mind, would a 10 or 12 be better? I've had two Type R 10s ported in a prefab (hated it), and currently have 1 Type R 10 sealed (it's not bad, but quiet). Now that I have Polk MM6501s amped, I need an upgrade for the sub.
Well I listen to 95% Dubstep and I just ordered 2 SA-12s today. After much research and discussion I feel like I made the right choice. They are going in a ported box tuned to 32 HZ running off my RF Prime 1200.1D. Get someone on here to design a box for you, its what I did. Buck is a genius at box building so I might give him a shot.
I have had my SA-12s installed for a few days now. Pumping about 650W into each of them and they slam when they're in the right box. Could easily, so easily, handle A LOT more power. But that is my .02 now.
465
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
Teej
Teej
Whippany, NJ
fatboytyler
    May 16, 2024
    May 16, 2024
