Sundown SA10 D2 (x4)
Cali_Screw
Rancho,CA
1. Product:
Sundown SA10 D2
2. Specs:
Re: 4.29 ohms
Fs: 35.4 Hz
VAS: 10.13 L
Qes: 0.52
Qms: 5.41
Qts: 0.48
Le: 3.41 mH
BL: 20.40 NA
Mms: 230 g
Sens: 81.0
RMS: 600 Watts
3. Description/Condition:
Two are in 100% mechanical working condition
One has a slight coil tick on certain notes, nothing audible if in the trunk
One is in 100% mechanical working condition, however has a small pin hole in surround.
Also have to recones if any one is interested in when buying.
4. Price: :
2 100% 130 Shipped each
1 coil tick 115 shipped
1 with pin hole in surround 120 shipped
recones 40 shipped each
5. Pictures:
one with the pin hole, you cant even see it
Recones i have available
Interesting, will think about that for sure. Thank you guys🙂
16
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have...
593
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
10
Cali_Screw
Cali_Screw
Rancho,CA
SUNDOWNBITCH
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
