Sundown SAX-100.4
n8skow
Sundown SAX-100.4D
Used, a few nicks and scratches, but not beat up.
4/3/2 Channel Bridgeable Class-AB Amplifier
MOSFET PWM Power Supply
Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
Variable Subsonic Filter
Independent 1/2 and 3/4 Channel High Pass Filter Variable
with x 10 Range Selectable Switch
Independent 1/2 and 3/4 Channel Low Pass Filter Variable
HPF/FULL/LPF Selectable Switch
Independent 1/2 and 3/4 Channel Electronic Crossover Slope Selectable
Switch with 12dB and 24dB Octave
Variable Input Level Control
Input Sensitivity : 200mV ~ 6V
Subsonic Filter : 10Hz ~ 500Hz
Signal Input and Line Out RCA Connectors
Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
Tested Voltage & THD: 14.4V & Less than 0.05% THD
Operating Voltage : DC10V~16V Power Input
Rated power output
RMS power, 4 ohm stereo
100W x 4CH
RMS power, 2 ohm stereo
160W x 4CH
RMS power, 4 ohm bridged
320W x 2CH
Signal to Noise Ratio >90dB
Low pass frequency crossover
50Hz~5kHz (CH1&2)
50Hz~5KHz (CH3&4)
(50-500 with x10 switch)
Selectable 12 or 24 dB slope
High Pass Crossover
50Hz~5kHz (CH1&2)
50Hz~5kHz (CH3&4)
Variable Subsonic Filter 10Hz to 500Hz
Frequency Response 10Hz ~ 40KHz (+/-1dB)
Bass Boost 0~18dB
Variable Bass-Boost Frequency Control 35Hz to 120Hz
THD@RMS Watts
Channel Separation 75dB
Fuse Rating 30A x 3
Input Sensitivity Variable 200mV~6V (+/- 5%)
Dimensions 252(W) x 58(H) x 480(L)mm
$250 shipped continental US
Will ship UPS Ground (insured)
As far as trades, I'd only be interested in a few specific items:
10" SoloX SPAIRS ('04 grey style)
10" L7's ('08 or '11 models)
Memphis 16-MC4.75 amp
Alpine PDX-F4 amp
Short Ram air intake for a Toyota
---------- Post added at 08:20 AM ---------- Previous post was at 08:19 AM ----------
will take a look when I go out to grab some lunch...
Is the white sticker still on the back plate
656
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
n8skow
n8skow
Kansas City, MO
n8skow
