sundown sax 1200.1
  • 4
crxjim29
nc
sundown sax 1200.1
i m new to selling here,i usually sell on ebay,they like there 9 percent,i sell a lot of great quality of subs amp etc,this is a little beast of an amp,and its not very big,its probably more like 1400 real rms watts,works and looks great,i prefer paypal.this was my personal amp,need to sell just got laid off,new to selling on this site,my ebay user name is jbw0077 100percent feedback on
selling car auidio
250.00 shipped
250.00 shipped to the 48 states
oh yeah here is the specs if you dont know Rated power output
RMS power, 1 ohm mono
1200W x 1CH
----RMS power, 2 ohm mono
720W x 1CH
----RMS power, 4 ohm mono
360W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~6dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 40A x 3
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 58(H) x 310(L)mm
Digital Class-D Linkable Mono Block Amplifier
Double Sided Through Hole Epoxy PCB
1 Ohm Stability
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry (Thermal/Over Current/Speaker Short/Speaker DC Protection)
RCA Line Input and Master Output
24dB Octave Crossover Slope
Variable Subsonic Filter
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Four(4) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~16V
Wired Remote Controller
MSRP $629 USD
563
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
crxjim29
crxjim29
nc
crxjim29
    May 24, 2024
    May 23, 2024
