Sundown SAZ-1200D
dross93ranger
Sundown SAX-1200D
This amp works perfect and looks almost new. The only issue is a couple terminal screw holes are stripped out, but still hold the wire well.
The SAX-1200D is the successor to the SAZ-1000D model - it features a newly tooled board taking advantage of newer and more powerful MOSFETs to achieve 20% more power in a casing only a little over 1/2" longer than the SAZ-1000D model that it replaces. Don't let the small size fool you, this amp is a little power-house!
The SAX-1200D is the perfect companion for a pair of SA-10s, 12s, or 15s.
Rated power output ----Rated power output ----RMS power, 2 ohm linkable/dual mono 2160W x 1CH ----RMS power, 1 ohm mono 1200W x 1CH ----RMS power, 2 ohm mono 720W x 1CH ----RMS power, 4 ohm mono 360W x 1CH Signal to Noise Ratio >90dB Low pass frequency crossover 35Hz~300Hz Subsonic filter 10Hz~60Hz Bass boost @ 45Hz 0~6dB Phase shift control 0~180 degree Frequency response 10Hz~350Hz (+/- 1dB)T.H.D @ 4 ohm
$260 shipped OBO
Included
603
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
dross93ranger
dross93ranger
Maysville, KY
blockburner
maylar
    Jun 2, 2024
    Jun 1, 2024
