Sundown sub question
  • 5
mixer4x
between the sa-12 and e-12, other than more power and probably louder, are the sound between the two similar? I would be using single sub, most likely sealed to spec or close and pushing 400 rms to the e-12 or 700 rms to sa-12 just as a moderate daily driver. I am just debating if it is worth paying $200 vs $110 for moderate bass in a camry trunk unless sound quality differs between the two.
Ok, thanks for the input. So recommended would be e-12 for sealed then, since I'd like to minimize space without going down to a 10" or smaller. Somehow, I just like 12" and it is a perfect size for my trunk, height wise. I know the sa-12 would be louder for sure, especially ported so I will have to think on that as well.
RDS Audio 6.5. He is making me a 1000 watt 8 with 23 mm of xmax also. Should be done next week. I built a box in trade for some cash and a box...
8
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have...
594
mixer4x
mixer4x
Minnesota
mixer4x
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
