Sundown subs
  • 4
LMJexploder
CarAudio.com Recruit
So I know Its not a good idea to mix different size or brand subs in the same enclosure, but would it be a bad idea to run 2 zv5 12"s and 2 zv6 12"s in the same enclosure. I would be running 2 salt 6ks, 1 for each pair of subs. I already have2 zv5s and everywhere I look there out of stock or discontinued. Thats the reason I ask about this setup.
Ok that's all great but the zv5 12 d1 is out of stock according to the website
I could be wrong but will that not create an unequal positive force inside the chamber? If they were all sperate chambers I don't see a problem. But if their married I personally wouldn't do it.
Then I would get the dual 4 ohm subwoofers and wire it to 1 ohm like in the link below. Those subwoofers are 500 watts rms so running them at 1...
8
Sorry for the double post, I meant to post this in the enclosure section. Mods can delete if needed.
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have...
499
LMJexploder
LMJexploder
Seattle WA
hispls
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
