Sundown x12v2d2 4th order
  • 6
OrzechNJ
Hello,
So I recently installed Sundown x12v2d2 with deafbound aab1500 amp wired to 1ohm in my 2020 dodge charger. Stock battery replaced with D4800 and secondary D3400, 0gauge DC/SHCA wiring, 8 gauge speaker wire, RCA's connected to PACamp pro in the back of the H/U. I'm planning to ugrade the mids/hights and sub amp to 2500watt in the future but I have to get this box situatuion figured out.
The sub is playng lows very well, but anything over 40hz sounds like ****. My guess is that box I build is tuned too low. I played a lot with crossovers and moving the box around but it doesnt sound any better..
I used subbox pro website to design the box and I cut it from 3/4" birch on CNC. Dimensions of the current box: 28wx14hx20.5d 2.5CF net and tuned to 32hz as recommended by Sundown. The port area is 40sq inch (3.18wx12.58"hx34.35l).
I was thinking to build a small 4th order. The max dimenions of the box: 30wx14hx20.5d.
Can somebody help me or refer me to the right person that could desing the box for me?
Disregard the hanging speaker wires. I had audiocontrol hooked up to the rear speakers before I install Pacamp pro..
thanks,
Pat
Imo if you are tuned 32hz that 40hz and above content should be fine. I'd explore signal issues 1st. X's are great down low yes but having poor response above 40hz shouldn't happen, it really sounds like the signal is filtered and/or boosted somewhere to me.
448
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
OrzechNJ
OrzechNJ
New Jersey
Jimi77
    May 12, 2024
Brendon Jenness
    May 11, 2024
