SWC wiring switch
  • 2
jmkcc
I have a steering wheel control wire that also sends horn signal. This is a modded steering wheel in my car and I do not have the OEM wiring. Basically SWC and horn receive 12v+. When the horn is pressed, it passes 12v to a module that measures resistance - if resistance is zero, it grounds the horn so it operates. If the resistance is not zero it passes the signal to the head unit as SWC.
The module will not interface with my car so I was wondering if it is possible to create some type of switching mechanism that will ground 12v zero resistance and send other 12v non zero resistance feed to the head unit. I'm not an electronics genius, but am good with sodlering gun and reworking station. So I could create a circuit board if someone can steer me in the right direction.
Thanks, JMK
Thats its manual fore using, not Tecnical.expaining , have pinted out service manual., and the cable i think was fore swc,its made fore satelite...
I assume the plugs are if you have factory equipment like a amp, etc.
945
Hello, I just installed a Chinese Headunit and wondering for the Steering Wheel Controls if i need something else or if it should work.. On some...
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
107
362
jmkcc
jmkcc
cape cod
JohnFoster
    May 18, 2024
    May 16, 2024
