SX's vs. HDC3-A's
Sx or HDC3
  • SX
    Votes: 8 25.8%
  • HDC3
    Votes: 19 61.3%
  • Who fukking cares
    Votes: 4 12.9%
  • Other
    Votes: 0 0.0%
  • Total voters
    31
well i don't need 4000watts daily...just might have to go with SX's if 1000watts is underpowering them
They do fine with 1kw each, just much more capable as far as power is concerned.. Unless the sx is substantially cheaper, I see no point in getting it.
same price point....and i've heard the SX's are extremely underrated as well
I would definately go with the HDC3.. I use to own SXs and WISHED i had saved up and got HDC3 (at the time HD3).. In fact, If Ididn have so much sunk into my 9515 and box, I would run 2 HDC3 12s
the copper ones are more efficient than the aluminums. i can't speak on how well they'd do on 1kw each, i wont have mine installed for a couple more weeks.
in jacob's testing with the aqs, was using 2000 or 2500 watts per sub, and said the aluminums were slightly louder at that power point. thats right about the coppers limit though, 2500ish. the aluminums can take well over 3k.
i might give them a bit more...maybe 1300 each
I did a 143.7 with 1 AQ HD3c 12 with copper coils clamped at less than 500 watts by DBSteve in Midwest SPL. I jumped up into the next class and did a 144.8 at 800ish watts (same guy clamping) with the same sub, same box, same show. The box was far from an SPL box. It was basically an AQ spec box in my explorer, although I tuned it slightly lower (35ish on the tuning). They are very efficient. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
how would 1 hdc3 15 copper coil handle an AQ2200 @ 1ohm?
then in the future, possibly get another whole set like that.
so one day run 2 hdc3 15's (copper) on 2 AQ2200 @ 2ohms (daisy chained)
thats all fine and dandy....except i need 12"s
bonesninja
bonesninja
Lima, Ohio
bonesninja
    May 12, 2024
Brendon Jenness
    May 11, 2024
