TC Sounds 15" TC-1000
ciaonzo
TheContinental
11,703
76
WI
15" TC-1000 single 4ohm
This is in great used condition with some light marks on the cone. A true unicorn among TC products, ultra rare and ultra SQ. Hard to find and very highly sought after driver. Dead silent suspension and awesome output capability. Thrives on very little power and easily absorbs more serious power. Check out the specs below. This is a sound-quality-first driver, meant for lower power and larger enclosures. Please don't buy this if you want something to piss pound, lol. Works well in sealed or vented enclosures.
Specs:
Fs - 15.6hz
Qts - .346
Qes - .381
Qms - 3.82
Sd - 320mm dia.
Vas - 393l
Bl - 15.01Tm
Mms - 283g
Cms - 433um/N
SPL - 87.8dB
The TC-1000 is the ideal driver for anyone looking for powerful clean bass with superb quality for either the home or mobile environment. With a standard 135 ounce magnet structure, 2" wide all aluminum 4 layer voice coil, and over 2" of highly linear excursion, this driver simply obliterates the competition. Its innate low distortion quality makes it seemly intended for high fidelity applications, but because of its high efficiency, impressive power handling and class leading displacement, the TC-1000 simply embarrasses retail SPL drivers with motors half its size! It can handle 400 watts of continuous power, but don’t be afraid to feed it 1000 clean watts as the voice coil will harness that power and deliver surprising sound pressure levels.
Advanced FEA Motor System
Double stacked 1" tall ferrite magnets and bored T-yoke for long throw
135oz top grade magnet structure
Anti-flux modulation copper shorting ring to lower distortion
Low carbon steel used for the gap plate and t-yoke
Pole vent for lower distortion and cooling capabilities.
Advanced high excursion soft part system
High excursion 8.0" linear roll poly-cotton spider
Intergraded woven leads to prevent lead-slap
2" diameter, 4-layer aluminum wire voice coil with an anodized aluminum former
Single or dual 3.7Ω (4 ohm nominal) voice coil configuration
Lightweight brushed and powder coated aluminum cone
1" wide long throw, highly durable NBR surround
High quality thermal flexible epoxies to ensure longevity
Performance
Effective motor force of 60 Newtons2 per watt (BL2/Re)
400 watts continuous power (1200 watts peak)
24mm BL XMax (voice coil, one-way)
37mm XMech (mechanically limited, one-way)
$300 shipped, CONUS.
CONUS only, please.
I would go sealed in that amount of airspace unless there's a chance you could add a second PR and tune around 20-22Hz.
It has two 15" PR's on the side. Would 3.5 after displacement still be too small even with two PR's tuned low?
I'm sorry, I was thinking you meant only one PR. Yes, 3.5 cubes is still on the small side but tuning low will keep it musical.
What kind of power and box would you recommend for this, ported box.
Ideal situation is a large enclosure with low pwer, just a few hundred watts. This keeps you well in control of the moving mass but not anywhere near thermal compression. But if you have to go on the small side you can bump the power up to 800-1000w. You'd need it for the amount of applied EQ in the smaller enclosure. It sounds pretty good both ways.
Hey, bud.
Yeah im lurking around a little bit. My lms8 i had for my ht setup finally died. Debating what i wanna do there.
Well, I know I don't need to explain the capabilities of the driver to you. You know what the 8" can do, lol.
Beautiful low distortion high(ish) output 15". Digs deeper than most of you have ever heard and gives a velvety smooth seamless transition to your front stage.
Someone out there has to be interested in sound quality!
Could you do $210 shipped to 36830? I'd love to put this in my home theater //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Afraid not, but I appreciate the offer.
Hmm.. I suppose I can do 245. Would you suggest a sealed or ported box for HT use? I'm planning on using this to do sub bass, and a pair of TC7's for bass in a medium sized room.
I was able to log in fine, using Chrome if that helps. I don't know anything about the product at all, just found the info and shared the love. :)
4
630
Brother in law has some of their 8’s and they are little beasts. Typical cookie cutter product that performs as it should.
Off the shelf design, nothing special and will sound like a bull horn. The best pro audio drivers I’ve heard are the crossfire XTpro6’s. The best...
6
ciaonzo
TheContinental
ciaonzo
WI
ciaonzo
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
