TC SOUNDS OEM 10'' D3 ohm
my_stealth21
Tulsa,OK
TC SOUNDS OEM 10''
TC9 motor with dual 1'' slugs same as Audiopulse REVO. Beleived they used the TC2000 coil on these. Id say 1200 -1500 RMS.
Qts 0.357
- Qes 0.400
- Qms 3.35
- Fs 30Hz
- Res 3.11 ohms
- Ls 4.0 mH
- Lp 6.26 mH
- Rp 9.9 ohms
- Dia 208mm
- Vas 19.3 liters
- Mms 224 grams
- Cms 119 um/N
- BL 18.35Tm
- Spl 83.3dB
Id use 1.3 net @ 30hz for ear *** !
This TC OEM 10'' is in great condition the suspension is so stiff I kinda think its barely been used. The previous owner was a all out sq guy off diyma so pretty sure he barely used it. There is a small rub on the surround and a little rub on the side of the basket otherwise shes mint. These are awesome drivers with great output and sound quality.
200 shipped. NO TRADES
UPS,FEDEX
I was able to log in fine, using Chrome if that helps. I don't know anything about the product at all, just found the info and shared the love. :)
630
Brother in law has some of their 8’s and they are little beasts. Typical cookie cutter product that performs as it should.
Off the shelf design, nothing special and will sound like a bull horn. The best pro audio drivers I’ve heard are the crossfire XTpro6’s. The best...
my_stealth21
my_stealth21
Tulsa,OK
my_stealth21
    Jun 1, 2024
    May 31, 2024
