TC Sounds Underhung NeoRadial 18
ciaonzo
TheContinental
11,703
76
WI
18" TC Sounds beehive neo underhung D2
This is for the complete 18" driver in beautiful physical and mechanical condition, no scratches or dents. Loud as ballz and more than I need. Specs below. If interested, I have coils and parts to build this motor up into other awesome drivers. We can work out the cost of those parts through PM.
Qts .33
Qes .35
Qms 6.9
Fs 27.9
Re 3.01
Vas 233L
mms 279G
cms 116 um/N
BL 20.7
Sens 93.5 1w/1m
1k RMS / 4k dynamic
$750 shipped.
UPS Ground, CONUS only.
Do you have soft parts for 5100?
I have 2 pro 5100s that are having issues. They are not vlown, but one side of the coil acts like a short until it gets enough power, thEN they are fine. But it drives me nuts.
Btw running in home theater
Do you have soft parts for 5100?I have 2 pro 5100s that are having issues. They are not vlown, but one side of the coil acts like a short until it gets enough power, thEN they are fine. But it drives me nuts.
I've had similar issues with Audiopulse drivers and was able to determine that it was lead continuity. If you can carefully work back the epoxy in the area of the solder joint, you can try to reflow it or add more solder. Can be a real PITA, though.
I should mention that this driver does not exhibit this issue whatsoever. I tested it extensively for that specific symptom and it is solid. The only reason I am even willing to let this driver go is that I am using a McCauley 6174 instead. Sent you an email with pic links and some info on the parts I have available. I will respond much faster through PM than email. Thanks!
Yes. For your view pleasure.
C'mon guys, don't make me put this on feeBay. I would rather someone in the community benefit from this monster.
Bottom dollar $675 shipped, in original packaging.
Thanks, fellas.
I should build up a couple different tops and just keep this. The 18" is just more than I need.
Was thinking about doing a soft suspension 12" or 15" for lower power musical setups.
Weekend whiskey bump.
I was able to log in fine, using Chrome if that helps. I don't know anything about the product at all, just found the info and shared the love. :)
4
633
Brother in law has some of their 8’s and they are little beasts. Typical cookie cutter product that performs as it should.
Off the shelf design, nothing special and will sound like a bull horn. The best pro audio drivers I’ve heard are the crossfire XTpro6’s. The best...
6
ciaonzo
TheContinental
ciaonzo
WI
germanyt
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
