The big 3 help
  • 4
since an earlier post said you did not need a fuse between the alt and battery. i was wondering if you were supposed to have any other fuses once you install the wire. if so what fuse?
People told you THEY don't use them. That doesn't mean you shouldn't. EVERY WIRE that comes off of your battery should have a fuse within the first 18" of it.
A dude had his battery explode pretty much because of no fuse in the stickied thread. The wire's ring terminal grounded out on the alternator casing and the battery started bubbling and being scary. That's like - a few millimeters between happy charging and scary bubbly battery. In that situation I would use a fuse //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
Ok I didn't really think it mattered because ground is ground just wanted to be. Sure. So I'll do alt to bat, batt ground to alternator mount, and...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
3K
James3
James3
Nashville, TN
James3
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
