thicker mdf better box?
It really comes down to what kind of subs your going to use. If you got some kenwoods then even 5/8th would work, lol. If your gonna use some competition subs then you could use a 1" face plate and 3/4" pannels or go 1" all the way around. It really does depend on what subs your gonna use, for example if its 2 JL 13W7's then you have to build a 1" box all the way around and it should be braced. Check to see what the sub manufacturers recommended enclosures specs are and start there.
I make lots of boxes. I never laminate two boards together, may lead to vibrations. MDF is very pourous. I would always paint the inside of the box to help close the pours. One inch MDF makes a good faceplate, especially for heavier woofers. I have only seen one company use one inch this much, Atrend, and I like their boxes.
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
Yea. That's what I did. I mixed the glue with the dust from sanding and fill in the bigger holes. Then filled the rest with wood filler..works awesome
9512 lol If you're in that realm of woofers, there's quite a good selection outside of those 2, but DD is a very good pick IMO.
1-12-t1
1-12-t1
Mesa, Arizona
Bassman200
audiobaun
    May 19, 2024
    May 19, 2024
