Thoughts on the Sundown Salt Bass Knob?
WorldsLoudestCreature
CarAudio.com Recruit
44
Georgia
Was trying to see which bass knob is more accurate and worth getting obviously ill be running a salt amp if I get the salt knob. The other option would be a limitless slam panda knob. If there are another awesome quality bass knobs I didn'tist please do! Thanks in advance for your valuable opinions!
how can a bass knob be accurate??? they all function the same way and you will see no difference, dont waste your money.....just use the knob that comes with what ever amp your getting
When I say accurate I'm referring to the volt meter/clip meter/temp meter , on the sundown salt knobs.
If the salt knob comes with your salt amp, you might as well use it. Voltage, clipping, and temp are all easy to verify if you have access to test equipment. If you doubt the company's ability to make a bass knob, why the hell are you buying an amplifier from them?
Jeez, don't gotta be all negative. Wasn't doubting anything I wanted opinions. Lol
Polk DB seem to always sound so much better than most for drop inns...
848
I treat my vehicles to an extent where they become some of the quietest examples of that vehicle. It isn't cheap if you're buying quality...
Looks like you could raise the back seat maybe 2 to 2-1/2" use longer seat bolts and washers and frame/mold in the under carriage cavity of that...
14
Georgia
audiobaun
    May 19, 2024
    May 19, 2024
