Thumbs up cab 1600
That zapco would be amazing. I'm to poor lol to afford something like that. Eventually want to updgrade to a crescendo encore 4.5k. Want to meter first and see. And sub and port up was way to go thanks @hertzmafia for the help on design. Moves a toooon of air. Can do some wicked hair tricks already :)
---------- Post added at 09:43 PM ---------- Previous post was at 09:43 PM ----------
I'd love a taramaps bass 5000. Gonna beat the heck out of these for the summer while stacking up some coin and tax time buying a solid amp with some refund and savings. By then may be ready to recone and basket to 18s and wall it off....
Im only getting 1 amp for the pair. And 200 to 400watts for components...im unfortunately governed by a 95 amp alt. No one makes a bigger one
Look into lithium batts. Some like to be charged at a lower rate I do believe.
Yeah my buddy Corey already told me but gotta man down a lame *** garage sale for the wife this weekend. Plus lil bros b-day. I'll see what I can try and do. Where's it located?
Well , I've had my issues with the CAB amps.. "possibly caused by me"... Mine was warrantied with no problem... For $200 it's almost a throwaway amp but since that happened I've loaded mine at 2 ohms each and tuned a little lower..."28 hz" and even though I'll tear it all apart someday eventually for sure... I'd recommend these amps to anyone tryin' to save a buck! With the current setup you just cant listen to decaf at high volume for more than a minute at a time... it may not hit big SPL but playing some slowed and lows it kills it for a couple of 12's. Also be ready to upgrade the electrical and dampen the car for sure. 1/2 ohm each may cause problems because strapping into 1 ohm is not recommended but insane power if you manage to not have the amps go into protect... Good Luck! The closeup of the black amp was the board shifting in the heatsink..Don't think you can load these at LOW impedance and they'll last... It could have been mounting it on the original box I had that caused this, but I digress... Mind you these amps never went thermal one just quit one day! Remember that 2 of these strapped @ 2 ohms is +3000 watts, if you got the electrical tight! For $200 ea it's a great deal...
That was my plan. Did not mean to thread Jack
I just want more loud. Right now I'm currently running 1 Icon 12 D2 wired to 1ohm. A 1200 watts. And 2.5 cubes. 30hz.. the plan is another icon 4.5 cubes. 35hz. 800watts apiece.. I hope it gets a little louder
Number 1 rule of the internet: Whoever gets mad first loses. I can't cure your insecurity. - "guy who gets petty"' Why are you so riled up?
98
13K
You could fit 2 SVC Dayton HO 10's ported behind that seat no problem.. You would need a amp that puts out power at 2 ohms.. If you had bucket...
14
Ok so I started my install . I am doing it in stages so I am not without music for a week or two . I started by building and mounting the Amp...
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
5
Lbetts818
Lbetts818
Midland mi
Lbetts818
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
