Tight zip ties on wire rises resistance?
loudenuff
WA gwon?
I just read a post from another basshead on Facebook that he proved tightening zip ties around any of your wires will add resistance. Anyone else prove this? I don't have time in the coming days to test this but I have every wire in my rig zip tied one place or another. Interesting knowledge if this is proven.
Wire resistance is a product of surface area and length. With power wires i highly doubt it could have a measurable effect. With speaker wire it might be possible to cursh the wire enough to change the amount of surface area. If your zip ties are just snug it wont do anything. Most zip ties will snap before tightening enough to deform the wire enough to cause a negative effect.
The jacket wire is ran through creates thermal resistance. If you remove the jacket completely, wire can handle more current.
So, anything "can" create resistance but it'll all go back to this- So does fuses and I like to be safe first, fun second.
**** no.
Theoretically the closer you can make your + and - speaker wires it will lower the inductance of the speaker wire
Thus lowering the total impedance (resistance)
BUT!
Sub woofers already have an absurd inductance compared to wire and the low frequencies played with sub woofers means it really won't change anything
Now if you are getting into tweeter range 10khz and up there could be some validity to keeping speaker wires tight together
ive only seen it become a problem with rca's or wire ~20 gauge or smaller
but its all relative, get a big *** zip tie tight on some 4 gauge and itll be similar to bending it sharply around a corner and youll get higher resistance
Joining FB groups is probably a bad idea...because of a lot of misinformation going around. Don't believe everything what you read/see.
loudenuff
loudenuff
WA gwon?
Boomin_tahoe
    May 18, 2024
    May 18, 2024
