SounDrive Pro Seller
www.soundrive.audio
It's not. The DP is a 3" 4 layer aluminum coil.But what if the 3" is a 8 layer copper and the 4" is 4layer aluminum?
But his is custom though. Just curiousIt's not. The DP is a 3" 4 layer aluminum coil.
i understand the DP will be alittle more efficient but i cant see it by that much. They are only rated 500 watts difference. I also read that the Treo is only 4 layer coil also.The DP will be a more efficient sub if the SSX is a 4" coil.
yea of course i wont expect it to do a 148 though**** thats pretty good.
The MMS difference is pretty big. The DP is a great sub, I see no reason to make that trade IMO.i understand the DP will be alittle more efficient but i cant see it by that much. They are only rated 500 watts difference. I also read that the Treo is only 4 layer coil also.
---------- Post added at 09:13 AM ---------- Previous post was at 09:12 AM ----------
Well it has its Pro's and cons. Me taking the trade i will have a much better suited enclosure for my vehicle. Also i will be able to wire a little higher on my amp. My electrical is not strong so the .7ohm is kind of harsh, so i will be able to wire to 1ohm thought thats not much difference. Also the Treo will sound better then the DP daily music and lows wise. I have noticed that the DP doesnt dig that low, it will play pretty decent but lacks on the low end.The MMS difference is pretty big. The DP is a great sub, I see no reason to make that trade IMO.
