Trouble with JVC KD-SH77
  • Thread starter <Intel>
  • Start date
  • Replies 2
  • Views 2K
  • 1
<Intel>
Guest
Help! My JVC KD-SH77 head unit does not play CD anymore. This happened a few days ago. After listening to a CD disk for a while, I decided to change the disk. The unit ejected the disk ok, but then it rejected to insert CD disk anymore. The motorized slot simply didn't switch on to pull the disk. I tried several other disks, no result. I pressed the reset button that didn't help either. I pushed the reset button with the front panel open, and the disk moved in, but it did not help a lot, since the unit did not recognize the disk and only played FM radio. Besides the front panel remained open and wouldn't close. With a combination of the button for changing the front panel angle and the eject button I could eject the disk, and then I gave up. This was around the New Year Eve when the dealers were close, and then I couldn't find time to go there. Is this a problem anyone has any expereince with?
Hey bud
try pressing the reset button on the unit this will erase all of your settings (stations/clock and all) it should be a very small dimple button located either on the face, or behind the detatchable face. Look at your owners manual it should show where it is. Grab a paper clip or something to press it with. If you don't find it in the manual, just look a little it is there. looks like the time set button on a casio digital watch
Originally posted by Help! My JVC KD-SH77 head unit does not play CD anymore. This happened a few days ago. After listening to a CD disk for a while, I decided to change the disk. The unit ejected the disk ok, but then it rejected to insert CD disk anymore. The motorized slot simply didn't switch on to pull the disk. I tried several other disks, no result. I pressed the reset button that didn't help either. I pushed the reset button with the front panel open, and the disk moved in, but it did not help a lot, since the unit did not recognize the disk and only played FM radio. Besides the front panel remained open and wouldn't close. With a combination of the button for changing the front panel angle and the eject button I could eject the disk, and then I gave up. This was around the New Year Eve when the dealers were close, and then I couldn't find time to go there. Is this a problem anyone has any expereince with?
Hello! Your JVC KD-SH77 head unit does not play CD just inside the laser head dirty only, you may use a lens paper to clean the laser head these all, your CD player will be a good feature.
Bye Bye
Hong Kong Agrotech
Seems kind of stupid to prevent helping others with advice on equipment from Amazon, doubt that Amazon is preventing this either. Pain in the arse!
14
932
U have to ignore that idiot !...thats the next thing i would do is check wires.i would run new beings how the wiring is old.
7
988
Try tracking down your leak. Check your trunk, and around your antenna wire.
Back in the late 90’s, I took my S-10 to Pigeon Forge Tn for the Mini Trucking nationals. The cops there were the worst that I ever seen. They...
8
I'm not a big fan of Brand X personally. My car idles at 500rpm and my Autotech didn't turn on until 650. I sent it back and he redid it to turn...
4
865
Guest
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
