Trying to choose an amp
  • 5
Right now I'm running SQ HDS315s on a ZX1500.. I already had the amp before getting the subs so I got them in 2 ohms.. I want to increase the power on the subs so I need an amp that gets that kind of power at 2 ohms..
Well the KX2400 is $500, so I'm willing to spend about that much..
I'm in the process of moving the subs from my 99 suburban to my 07 Tahoe.. Stock electrical for now but I'm going to do the big 3 upgrade and change the batter to a yellow top.. Running 0 gauge amp kit.. Kicker amps aren't stable below 2ohms
Id run a pair of amps and gain match with a DMM .Have you looked into the PRV amps??Im still debating on snagging one up soon to try out.
341
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
740
Just need to find id to get a users Manuel thanks
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
Ike_Turner
Ike_Turner
Hattiesburg, MS
mclerico83
