Tsunami db1800T
  • 4
18inchjeepin
Muncie, IN
Tsunami 1800 Watt Class T Digital Power Amplifier
circa 2002
Advanced Tri-Path High Efficiency Digital Design
1x 900 WRMS @ 4 Ohm Mono .1% THD
1 x 1800 WRMS @ 2 Ohms Mono .5% THD
High Thermal Efficiency Heat Sink Design
Distinctive Backlit Logo Badge
Signal to Noise Ratio -90dB
Variable Input Sensitivity 250mV to 6V
Variable Low Pass Filter 50-250 Hz
Variable Sub-Sonic Filter 15-50 Hz
Variable Phase Control 0-180 Deg.
Remote Gain Control
Current and Thermal Protection
In pretty good shape, there is a scratch by the paper plate. The previous owner said the RCA outputs do not work, but I have not checked.
Also the owner did not mention anything about the input jack being messed up, but I ran a splitter(INCLUDED) to run both RCA's into one and it worked perfectly
$180 SHIPPED O.B.O.
free
18inchjeepin
18inchjeepin
Muncie, IN
Exist_ential
