Turn Signal and Marker Voltage drop.
TheJuggla1
Surrey BC
I have a voltage drop when I have turn signal markers or 4 ways on. These aren't like huge bulbs or anything, I don't see why I should lose .5-1 Volts having my markers or turn signal on.
Nothing else in my system causes any voltage drop(Except obvious stuff like heads light and heater which use a fair amount of power)
Should I redo all my grounds? I'm not sure about the tail lights, can I cut of the tail lights ground right after it leaves the tail light and just ground it right behind the tail light? Same with the front markers?
Also I get a bit of stereo whine when my heater is on or I am using power windows, is this a bad amp/HU ground, or is the ground on the heater/power windows causing it to whine?
Separate note, I wanna do the big 3, I am going to use 4 gauge wire from atl to bat, what fuse should I put on this(And where right after alt or does it not matter?)and whats the best way to run the wire, the alt is on the opposite side of the vehicle than battery.
i get voltage drop from my turn signals as well but not from when i have my system at full tilt. not sure what the problem is though:crap:
Maybe the relay's require alot of volt/amps to energize? Either way, I don't think it'd affect your system too much //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Whenever I roll two windows up @ night my headlights dim. Pretty odd but I don't get voltage drop from turn signals. Just thought I'd share
It'd be interesting to look at the fuse box and see what these items are drawing when operational.
Maybe two windows at once is like 60amps constantly or something crazy like that. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Yeah I get dim when I power my windows up. The more windows I do at once the more I dim lol
When I first noticed it I was riding and would hold all four and it would dim like crazy...I did it repeatedly..pretty wild lookin haha
Wouldn't surprise me....everybody says expeditions are electrical nightmares...with all the problems I've had...I'd say they were right
Have you tried different relays? Slower/faster ones etc....
My blinkers are pretty fast and there is no recordable voltage drop.
Seems like your relay is just getting old and drawing more current.
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
792
Hello! i have too problems with head units, two cars, old mazda 323f ba and now mazda 6 2007r station. Problem is from lossing quality, poor bass...
973
Pull the head unit out, and at the harness use a test light to check 12v, ground, and Accessory. If all three are good, you have probably...
Nothing wrong with the system. humming sound. Just the amplifier. Just switch it to volume maximum, then enjoy the music there. Loud. Sorry...
TheJuggla1
TheJuggla1
Surrey BC
TnT_Sounds
    May 10, 2024
3toneEYZ
    May 10, 2024
