tweeter ohm?
  • 4
Is there something wrong otherwise? Are they not making any sound? Put your ear next to it, you'll know if it's working.
You aren't measuring the tweeter only when you measure it with the crossover connected, you're measuring the entire circuit.
Is there a problem you're having with the setup or were you just curious?
The tweets seem bright and i didn't want to blow them if they are 1 ohm. I just found it odd. BC on the crossover using a ddm i put it on the woofer and it was 4 ohm and tweets where measuring 1 ohm
Back deck, over trunk. Certainly not air tight. I know it’s a dramatic difference in chest compression when the back seat is open to the trunk...
29
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
553
I'm taking them off the midrange pods as they aren't needed. I have a set for the tweeters that are much more important but not installed in the...
20
Tons of options in that budget, including the cost of installation,
10
bradl79
bradl79
NLR
nismos14
maylar
    Jun 2, 2024
    Jun 1, 2024
